Ga door naar hoofdinhoud
The Toyota RAV4 was redesigned for the 2006 model year using an all-new platform and was first unveiled at the 2005 Frankfurt Motor Show.
11 Vragen Bekijk alle
How do I locate the fuel pressure gauge on a 2008 Rav4?
My ODB2 is showing 2 errors regarding the fuel pressure sensor. if after inspection and possibly testing, I might want to replace it.
Is dit een goede vraag?
1 Opmerking:
Tim Tucker what codes are you getting?
door
Voeg een opmerking toe
1 Antwoord
Fuel pressure sensors may not be what many assume. EFI systems monitor fuel vapor pressure and vacuum in fuel tanks when emissions control programs test for leaks in sealed fuel systems while the vehicle is driven. Less than 2 psi of vapor pressure and low vacuum is measured with a combination fuel pressure/vacuum sensor mounted on the fuel tank. OBD II systems on USA marketed vehicles perform emissions testing every time the engine is started and during vehicle operation.
Was dit antwoord nuttig?
Voeg je antwoord toe
Tim Tucker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 396
