Ga door naar hoofdinhoud
This page was designed to provide users with repair guides, manuals, and troubleshooting help for Lenovo IdeaPad 1 14IGL05.
Why is my touch pad is not working
My touch pad is not working
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Is it a Synaptics or Elan touchpad?
Which ever it needs to be turned on as so:
  • Make sure the touchpad driver (for example, Synaptics or Elan) installed on the PC is the latest. If not, go to Lenovo support site to download and install. Otherwise Device Settings may be unavailable. Search to open Control Panel --> Mouse. See Where is Control Panel?
  • In the Mouse Properties window, switch to Device Settings or the Brand name tab.
  • "Synaptics": Click Enable. Click OK to continue. "Elan": Click Enable Device or Stop Device. Select Disable when external USB pointing device plug in to disable the touchpad when a USB mouse is plugged in automatically.
  • Click Apply --> OK. The touchpad will be enabled.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jake Adams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 128
Altijd: 3,341
