Ga door naar hoofdinhoud
De Samsung Galaxy Tab A6, uitgebracht in 2016, is een mid-range tablet die ontworpen is in de stijl van de Samsung Galaxy A-serie telefoons.
Can the version of android be updated
Tablet is running version 5.1.1 - can it be upgraded?
Thanks
Is dit een goede vraag?
Score 8
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It can run up to Android 8.1
Was dit antwoord nuttig?
Score 3
7 opmerkingen:
Thanks guardian10.
I went to settings - about device - software update and it downloaded an update and installed it and optimized apps. But, when I look at about device it still shows version 5.1.1.
I restarted the tablet and it still shows version 5.1.1.
I tried software update again but it says it is up to date.
Any ideas?
Thanks
door
@rick fredricksen That is very odd. I do not know anything beyond that. I have not worked on Android tablets before. I mostly work with Apple products. Are you sure it is a Galaxy Tab A6?
door
yes it is a Galaxy Tab A6
door
Try updating again, if that moves you up try again until it doesn't say an update is available. OTA updates tend to go a step at a time not all in one great leap... yes it s weird.
door
I have the same tablet; mine was updated a while ago to ANDROID 8.1.0
Jan Broenink
door
2 commentaren meer tonen
The Samsumg Tab 6A has a small porblem If you have the SM-T280 it cannot be updated or even rooted. Check your model number.
Score 1
3 opmerkingen:
That is unfortunate. I have that nasty SM-T280 :-( Thanks fro the heads up because I have been trying to wrestle an update for some time. Have a great day.
door
As noted before, The Samsumg Tab 6A has a small porblem If you have the SM-T280 it cannot be updated or even rooted. Check your model number.
door
You're wrong. There is a version of supersu for it, and a version of TWRP, Lineage OS and E OS. All are built by the community, and have barely any bugs. Updatable up to android 7.1.1, or 8.1 if you find a custom rom for it.
door
Voeg je antwoord toe
rick fredricksen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 65
Altijd: 8,452
