Ga door naar hoofdinhoud
De CFS-204 is een analoge AM/FM-radio en cassettespeler uit de jaren 90. Deze kan worden gevoed door zes C-cel batterijen of door stroom uit een standaard stopcontact.
Broadcast fuzzy when light switched on
Whenever I switched on the ceiling LED light the radio broadcast became fuzzy with static interference but not so when switched off the light. And this only happened with that one particular light but not with other similar lights in the house . I tried to disconnect the earth wire but it didn't help. I also tried replacing it with another unit of similar type but problem persisted.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
A lot of cheap LED bulbs do this, so you probably put a bulb in that caused the same problem. Radios and cheap LED bulbs do not mix, ever.
You need to look for more expensive bulbs like GE or Feit Electric, especially with a radio.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
thanks Nick. will try this solution.
door
Het nuttigste antwoord
Hi
Did you change the LED driver (aka LED transformer) or only the LED light?
If only the LED light then most likely the problem is with the driver.
The driver is what converts the AC input to a DC output to power the LED light.
Score 1
1 Opmerking:
I did change the driver as well but it did not fix the problem.
door
Voeg je antwoord toe
alexee1959 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 437
