Keyboard Backlight Problems MBP17 Unibody
Hi I have two Unibody MBP17 a matte and a glossy screen, I changed out the two displays and has a keyboard light does not work both PLEASE HELP!!!!
Is dit een goede vraag?
Hi,
Have same issues with my A1297 MacBook Early 2009 MacBook Pro 2,66 GHz
After changing the uppercase my backlight does not work properly!
I noticed, that covering the sensor near the camera turns the keyboard backlight on,
BUT I CAN'T CHANGE THE BRIGHTNESS (NO F5 AND F6 BUTTON WORKING!)
Cable was checked and is connected.
Does anybody have any suggestion, where the problem could be? When i push the button, it's greyed with a prohibitory sign...
Any idea? Thanks in advance!
== Update ==
Problem solved: Covering the light sensor next to the camera --> f5 f6 work (dark)
if it's bright outside --> f5 f6 are disabled
Thank You anyways
Was dit antwoord nuttig?
Try resetting the SMC.
What kind of picture? Both of them is the same type MBP17 unibody 2.66 ghz/ both of them are working perfect after I changed the displays the keyboard back light is not working
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,375
