Magsafe Charger not lighting up at all
To give some backstory on this MacBook Air had water spilled on it, the person who spilled the water had put the laptop in a tent position waited for probably an hour then tried to attach the MagSafe cable and power on repeatedly.
After no success he gave up, and I offered to attempt to fix it for him. There was minor corrosion in multiple spots of both the logic and I/O board as well as the CPU heatsink thing.
I remove all those parts and put them in a ultrasonic cleaner with distilled water and 5% elma tec S1 solution at 62 degrees Celsius for 2 minutes. It appears that had removed the corrosion, inspected the logic board closely for any signs of discoloration/damaged pins and it looked good to me (also reapplied thermal compound to attach the heatsink).
I then checked the I/O board and where there was previously corrosion I saw there was a somewhat burnt discoloration on the board itself. After the ultrasonic cleaning I used a Multimeter on it to check connectivity throughout the board (I honestly didn’t have much of an idea what I was doing with the multimeter in terms of understand what I was suppose to interpret).
I will post some images of what the I/O board in question looks like and possible a pic of the logic board itself, thanks for the help in advance.
Is dit een goede vraag?
