Factory reset keeps failing with error 4013
I’m trying to find an app that will force a factory rest on my iphone 6
Is dit een goede vraag?
If you’re getting an error trying to reset with iTunes and you have already tried using another USB cable/port/host machine, more than likely this error is a hardware fault in the phone. Error 4013 is less specific than some other errors, but in my experience, using a different app to reset is not likely to fix this issue and may actually cause further issues. Error 4013 specifically is often a logic board related problem
If I recall correctly, on iPhone 6, it can be related to NAND (the device storage), but could also be related to any number of other board level issues. Either way you would likely need someone to diagnose and repair the logic board itself to resolve the error.
Was dit antwoord nuttig?
thank you for taking the time
if you got an error 4013 on iTunes restore means Nand cluster was damaged. You have to reprogram it.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 43
