Ga door naar hoofdinhoud
Reparatie-informatie en handleidingen voor de vernieuwde versie van de 2015 Retina MacBook die begin 2016 werd uitgebracht. Model A1534 / EMC 2991
MacBook No Startup Disk?
Hello, I have a MacBook Retina early 2016 which I tried to reinstall the OS on however it told me there was no starting disk, how can I get one or install one? This MacBook has a soldered SSD and RAM, and no disk slot so I’m guessing its something I have to install. Thank you for your help
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Looks like you can boot into recovery mode. First run Disk Utility and see if you can repair the storage unit. If not you may have to reformat the drive and then try installing a system.
If it were in a shop, they would try using an external drive to boot from and work on the storage.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I repaired the hard drive, but unfortunately the issue still persists. What do you mean by "report the drive"? Also, I'm not sure if this has anything to do with the issue but the screen flashes to white and grey every 2-3 seconds before returning to normal. If you need a picture of it glitching like this let me know, I can upload one
door
Spell check error - corrected "reformat"
door
These Macbooks are relatively prone to fail because of failing memory chips. Since it seems software "repair" didn't fix the issue, there's nothing else left but a board replacement.
Score 1
Voeg je antwoord toe
Colby Morris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,340
