Ga door naar hoofdinhoud
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
Why is my computer corrupting its SSD?
I have a 2010 MacBook Air and every couple of hours it crashes and when it tries to boot again it shows a folder and a question mark. When I enter recovery mode, open disk utility, and use the first aid tool, it repairs stuff and then my computer works fine again. Is this because of the SSD or something else? I have already tried reinstalling a fresh copy of macOS high Sierra.
Is dit een goede vraag?
3 opmerkingen:
What is your drive? Apples or someone else's and the drives details.
Also, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
I have apple's original 256gb Toshiba ssd
door
It only has this problem once it heats up.
door
Voeg een opmerking toe
1 Antwoord
If thats the case it does sound like the SSD is failing. This series uses a custom mSATA blade drive.
You’ll need to replace it, your options are limited either going with another Apple driver or OWC Aura Pro SSD and you might want to get a larger drive if you find your drive is more than 3/4 full. The reason here is you want to leave a partition of the drive unused so the OS and your apps have some elbow room for Virtual RAM, caching and scratch space use.
Reference: The Ultimate Guide to Apple’s Proprietary SSDs
Replace or upgrade the SSD in your laptop. This SSD is compatible with a Late 2010 or Mid 2011 MacBook Air 11" or 13" laptop. Afbeelding
Product
OWC Aura Pro SSD for MacBook Air 11" and 13" (Late 2010-Mid 2011)
$45.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Nathaniel Hellewell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 136
