Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
583 Vragen Bekijk alle
Won’t boot after logic board replacement.
Just did a straight swap of my logic board(820-3330-B) and it doesn’t recognize drive. Repaired with DU, with no results.
Is dit een goede vraag?
3 opmerkingen
@criticalmass316 - Please help us help you!
What is your OS?
What is your drive/s? Make and model
Did you replace the HD SATA cable?
door
Running Catalina on:
Model Name: MacBook Pro 15” mid 2012
Model Identifier: MacBookPro9,1/AC1286/MD103LL/A
Board: 820-3330-B
Processor Name: Quad-Core Intel Core i7
Processor Speed: 2.3 GHz
I did not replace the sata cable. The OWC ssd drive shows up in disk utility. It’s just not booting from it. Tried resetting password via terminal, nvram. I could try cloning it and then wipe it and do a fresh install. Just wanted to avoid it if possible.
door
Do you have a second SATA drive? if so you could try swapping it out and installing Catalina on that and see if it works. You could also try a new SATA cable.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Logic board swap out:
As you are running Catania your drive is running APFS. So a common issue is the replacement logic boards firmware is still the older version so it doesn’t know how to boot up under the newer macOS. I would use a bootable OS installer USB thumb drive to re-install the OS so the installer updates the systems firmware.
SATA cable issue:
This tended to be an issue with early versions of the system as Apple used at the time a SATA II (3.0 Gb/s) HDD and the cable was not able to support the higher data rate of the better 3rd party SATA III (6.0 Gb/s) HDD’s.
To add to it this cable is fragile! Your Hard Drive Cable Is A Ticking Time Bomb
As such when ever I replaced the drive with a SSD drive I always replace the cable as any defect in the cable will make you pullout your hair!
But, you also need to not man-handle the cable! As that too will damage it. Don’t crease the cable as people tend to do that for the areas the cable needs to bend. Creasing the cable damages the thin foil wires within the ribbon cable. Instead I use an old BIC pen ink straw making sure the bends don’t exceed the radius of the straw. I use the straw to help form the curl.
Make sure you get the newest version MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable and here’s the guide to put it in MacBook Pro 15" Unibody Mid 2012 Hard Drive/IR Sensor Cable Replacement
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable Afbeelding
Product
$19.99
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
So yeah, I dug a bit deeper and a notification popped up when I tried to reinstall Catalina that says I have to update the firmware. It wont allow me to even mount the drive until I do that I assume. Is there a firmware update that apple offers? The cable seems to be fine as I can clearly see and scan the SSD with DU in recovery mode.
door
If you create a High Sierra image that should update the firmware.@criticalmass316
door
Ok, just a quick rundown on how to do that @areeve
door
Using a second Mac download the macOS installer of the OS you want or at least get Mojave from here How to get old versions of macOS and then create a USB Thumb drive OS installer (32GB) first by formatting it to GUID and a Journaled file system using mac Disk Utility then follow this guide How to create a bootable macOS Mojave installer drive
door
Voeg je antwoord toe
Scott Dill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 298
