Ga door naar hoofdinhoud
The BlackBerry 8830 is a smartphone that instead operates on CDMA2000/EV-DO networks and includes GPS.
2 Vragen Bekijk alle
My blackberry 8830 blank out the screen
i have this blackberry 8830, it was working fine, but suddently the screen turn completely white, I turn it off and on back and didn't restore the screen. Now a have a BB that have a white screen that i can not anything.
Is dit een goede vraag?
Score 3
1 Opmerking
most bb I've had with a white screen need a new LCD
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Not sure if you already tried to remove the battery to reset the BB. You also want to try to reload the OS by using your Blackberry Desktop software. now what I read earlier, while researching another question, was that there is the possibility of a shortening out of some pins. Check on here even so it is for a Curve, it still applies to your phone as well. Hope this helps and gets you started.
Was dit antwoord nuttig?
Score 1
Hi, how are you? You must replace your LCD screen, before buying a new piece, look the backside on the broken LCD, there's a serial a number like: 007/111, 001/111. That's your LCD number, you must buy a new one that have that serial number. If you look around the site you'll find some guides that explain how you can replace the screen. I hope this helps you! Sorry about my English. Good luck.
Score 1
Agree with gonzalobonini, you'd better pay attention to the LCD serial numerber
Score 1
Dismantling screen
Dismantling screen
Dismantling screen
Dismantling screen
Voeg je antwoord toe
Ricardo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,418
