Ga door naar hoofdinhoud
The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
20 Vragen Bekijk alle
Right turn signal works oddly.
So, if we start the card and turn on the right blinker. It seems to work o.k. However if
turn on the headlights and check the blinker, no go. The front one works (fast) but no back blinker. Turn off the head lights, and the symptom stays. Looking at the wiring diagram shows that the lamp is operated by a unified electronic module. So, is it possible that the lamp has a bad ground or lead wire that shows open when the headlights are on?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
A rapid turn signal indicator light light is usually a sign of a faulty bulb or connection etc in the circuit front or rear.
if it is always the rear turn signal light that doesn’t work, check the bulb/bulb connection. It may be a faulty bulb (filament?), a lack of tension between bulb and holder, corroded, or have a bad earth
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jay Cotton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 88
