Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Vragen Bekijk alle
Probable short circuit on a iPad Air 2
Hi guys, I need an advice from an iPad repair tech. Got a Air 2 that doesn’t power up, no sign of activity. When I connect the charger I get 4.5v and 2.5amps on the usb tester. There probably a short somewhere. The iPad is not open yet, I checked the charging port under microscope and it seem perfect. So where could be the short inside ? Thanks, any help is appreciate :-)
Is dit een goede vraag?
2 opmerkingen:
If there was a short on power rails I don’t think you would get a draw of 2.5a through the charging port it would usually be 0a. Have you tried connecting to a pc with iTunes to see if it’s recognised.
door
Yes, still no activity connected to a Mac and nothing on iTunes. Could it be a short in the lightning port ? Thanks Daniel
door
Voeg een opmerking toe
1 Antwoord
hello lemerise,
You probably have micro cracks in the dock tape connection. 4.5V is not a native value via usb (it should be 5V) and the 2.5A draw suggests a charging problem in tristar's lines. You have to open device. Ipad air2 is enought mapped, you'll not have got a problems.
Was dit antwoord nuttig?
2 opmerkingen:
OK thanks, I'd like to have a tristar tester but I'll order this chip and replace it.
door
no, do not replace without checking (after all, it may turn out to be just a capacitor in the line). I am not a supporter of replacing elements with no 100% certainty. Get the meter and check the lines. You don't need testers, wonders, or sorcerers. Only knowledge and the desire to solve the problem.
door
Voeg je antwoord toe
lemerise zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 380
