Ga door naar hoofdinhoud
Power Light is always on and will not boot
Hello,
the Power Light of my Mac Pro is always on. I can switch on/off the Mac (when I push the Power Button, the 4 LEDs on the RAM Board light up briefly and then only 1 stays lit on-and the Fan also goes on) The same the opposite, when I push the Power Button for a short while, the one LED on the Memory Board goes off and also the Fan. But the power light always stays on no matter what I do. The only way to switch it off is to remove the Power. I have tried resetting the NVRAM, PRAM and SMC- sometimes I am successful ans able to start up, but then the next day no more.
Any suggestions would be greatly appreciated!
Thank you
Dorian
Is dit een goede vraag?
1 Opmerking
I forgot to mention it is a 3.1 Model, I think A1186 (?)
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I think its the power supply
Part: ???
Guide: Mac Pro First Generation Power Supply Unit Replacement
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I'm doubtful it's a power supply issue. I've tried 3 different working PSUs and they didn't resolve the problem.
door
Forgive me. I forgot to mention. I am running a 3,1 with dosdude 1's Mojave. The machine has now resorted to shutting down within 2 minutes after boot rendering it unusable.
door
Previous shutdown cause is -2. What does that mean?
door
@dwcdv - Did you try looking at the motherboard while its on with the sidepanel off,
look around for some lights near a button,
Press said button and post a picture of the lights
https://www.macspecialist.org/mac-pro-ea...
door
Voeg je antwoord toe
Dorian Weber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 193
