Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een betaalbaardere, puur handheldversie van de Nintendo Switch-spelconsole, met geïntegreerde Joy-Con-controllers en een iets kleiner scherm. Uitgebracht op 20 september 2019.
How To Remove stripped screws from back shell
while trying to open up the lite I stripped the screws by putting to much pressure on screw driver carving a shape into it I was able to get one out (it wasn’t stripped) I got the screws to replace them but I can’t get the stripped screws out it’s in the top left bottom left and bottom right
Is dit een goede vraag?
Score 2
1 Opmerking
I have a similar issue, I am going to try and put a tiny dot of glue on the tip of the driver, hold it against the screw till it dries and hopefully i can turn the screw afterwards...wish me luck!!
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
YouTube is filled with suggestions on removing stripped screws. However, look carefully because some of the methods are fine for removing a screw with a stripped head from wood, but would destroy something plastic, like your Switch. Don’t use a propane torch to heat the screw and don’t use any sort of impact tool.
It’s an art form and some methods won’t work at some times.
Rubber band - I haven’t found this works
Latex glove- I haven’t found this works
Mini screw extractor
Left hand drill bit
Metal drill bit
And others
Here are some vids that are focused on removing stripped screws from small electronic devices.
IFixIt carries this, which is shown in the last vid.
Precision Screw Extractor Set
https://www.youtube.com/watch?v=xaQ9eX-b...
https://www.youtube.com/watch?v=TEYgVsPc...
https://www.youtube.com/watch?v=s06UWk_N...
https://www.youtube.com/watch?v=wpgc9rAA...
https://www.youtube.com/watch?v=kfcU2f7S...
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Where did you get your replacement switch screws?
door Deel
Voeg je antwoord toe
mat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 217
Altijd: 39,217
