Ga door naar hoofdinhoud
Een USB-kabel (Universal Serial Bus) is een veelgebruikt type kabel dat wordt gebruikt om apparaten zoals computers, smartphones, printers, camera's en andere elektronica aan te sluiten. Het is ontworpen om gegevens en stroom tussen apparaten over te dragen, en wordt ook vaak gebruikt voor het opladen van apparaten.
15 Vragen Bekijk alle
How can I know if I have genuine Apple Lightning cable
Hi everyone,
I had an issue with Apple USB to Lightning cable and now I am wondering how can I check if I have genuine Apple cable. I get my cable from “second hand” (it was in original packing and it’s looks genuine - compare the one from Apple Store - no different at all).
I know there are some cable testers, but the price is high - if I just want check cables. So I am curious if there is any software ? So I can connect USB to my Mac and will know if it’s genuine or not.
Thanks all for any idea :)
Regards Rob
Is dit een goede vraag?
2 opmerkingen
Do you have a Windows computer?
door
Well somewhere I have Core2Duo with Windows XP :D - not sure if I can call it computer, but I have access to computers with Windows 10
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
First, Install 3uTools on Windows 10.
  1. Connect your iPhone to your PC via the cable you want to check.
  2. If you see a prompt on your iPhone to “trust this computer”, click “trust”
  3. Open 3uTools
  4. Click “Toolbox” at the top
  5. Click the “Genuine Accessories” tool
  6. Click “Test Data Cable”
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thanks a lot.
door
Hi guys,
bit update on this - get some new Apple Lightning cables so want to try if they are genuine products, but unfortunately when I follow advice from @andrewsawesome I get no information so I tried other cables - they are 100000% genuine Apple but with same result.
EDIT: but this software is surprisingly powerful :)
Any ideas why ?
Score 1
2 opmerkingen:
I haven't actually used this software yet. I'll try to download it today and see if I can replicate this.
door
@andrewsawesome thanks a lot :) no rush :)
door
@roboscrap Interesting...
When I used a USB-C cable that I'm 99% sure was not genuine, it showed the manufacturer as Apple A2249
But when I used a non-genuine USB-A to Lightning cable, it showed N/A in the left columns like you reported. Note that this one was bought very recently, but the date that 3uTools reports is from 2012
I'm not sure where my genuine Apple cable(s) is (are), but if I find them, I will update this post with more information.
Score 1
2 opmerkingen:
@andrewsawesome thanks a lot, will try more cables later :) also will try on another pc as this is from some 10.000 years old one.
door
@andrewsawesome So today I tried all my USB->lightning cables, and all of them have same result as above.
1 is from iPad Pro - bought in UK
1 is from Magic Mouse 2 (space grey) black cable- bought in UK
1 is from Apple Watch stand 2m - bought in Czech Republic
1 is from Apple Magic Keyboard (space grey) black cable - bought in Czech Republic
1 is 0,5m just cable bought online (so no idea where it's came from
1 is 1m just cable same like 0,5
(I may have some more - but these are what I am using now)
for last two cable was reason to install 3U software - I was wondering if they are original or not - everyone know how good are in China with "originals".
So I am not sure if 3U software working only with USA/Canada cables ? I will have chance to check some from Austria in few weeks so will see.
EDIT: I also used newer PC with W10 and USB3.0
door
You can see if the cable is real by checking the cable about 7 inches from the USB connector. It should say (apple logo) Designed by Apple in California assembled in China/Vietnam ([random code] FTU24578HDRD)
Forfeited cables wont have the logo and will most likely misspel something. One of my cables says Designed by Abble in California Assembled in Vietnam HTSX
I don’t know if you were specifically looking for a software that would help, but this should do the job
Voeg je antwoord toe
Rob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 205
Altijd: 6,572
