Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
3 opmerkingen:
@cyruca1 what exact model is your dryer? What have you checked? Did this just happen all of a sudden or were there any issues before
Check the vent hose and check that the pipe through the wall isn't clogged. If it's vented through an outside wall, then it's likely a really short, easy to access pipe that can be easily cleared, if it's clogged. If it's in an interior place, then the pipe unfortunately is long and could have bends in it. There are brushes that attach to a drill. The segments screw together, but duct tape or electrical tape the connections. You do NOT want it to come apart inside the wall.
door oldturkey03
Have you checked your breaker panel/fuse box?
door moe_r
door Ken Grubb
