Ga door naar hoofdinhoud
Reparatiehandleidingen voor grafische kaarten en videokaarten.
111 Vragen Bekijk alle
Does anyone know thermal pass thickness of nVidia quadro 4000?
I would like to repaste by quadro 4000 but I can’t find any info for pad thickness. This is a plain 4000 not RTX 4000 or any variant that starts with a letter. https://www.techpowerup.com/gpu-specs/qu...
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This may not be helpful and I am sorry.
I buy multi packs of thermal pads ranging from.
0.5mm, 1.0mm, 1.5mm. as these are most common.
I would say it would be either a 1 or 1.5mm thermal pad. I suppose it's narrowed it down a little.
If you build it with a 1.0mm and it's over heating and crashing try the 1.5mm as the 0.5mm can make a difference in helping the pads make contact.
I just use trial and error for work like this.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you. .
door
Sorry it isn't the best answer as I rarely work on these but I mean hopefully it will give you some guide
door
Voeg je antwoord toe
Duck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 560
