Left speaker driver is not working
Does anyone recommend disassembly of this device or can I send it back to Sony?
Is dit een goede vraag?
I had the same issue. For me, placing some thick paper on the circuit board did the trick permanently.
Was dit antwoord nuttig?
Yeah I think something like this would help stop the wires from shorting to the PCB.
Was a little sceptical at first but was so tired of having to hit the left speaker to make it work. Folded cardboard solution worked like a charm! Thanks!
THANK U SO MUCH FOR THE TIP. i bought the m3s 2020 with this issue outta the box, ive been hitting my left earcup since then just to get it to work every single time, i did everything, other pages suggested to remove the tape holding the wires inside, which i did and worked like a charm!! after a week exactly same issue back, recently where i accidently dropped the headphones a scary moment when i put them back on the left ear went off for good at least when in bluetooth mode, so today i searched again the internet i found again this topic which ive already came acrosss before but it didnt make sense to me to tape the wires back again!! i wanted to give it a try and move on.
i connected them to my phone turned the music on high volume of course the sound is available only on the right side, then i open the left side and applied pressure with my finger on the wires then the sound is back!!!!! i taped the wires to the board and added piece of thick cardboard on top. Thats it! thank you so much for the help again guys!
Same issue here.
When pressing on the PCB in the left speaker they started working fine again. Could not find the source of the issue. Cant be any shorting of wires. I isolated everything with capton tape. No lose or damaged parts inside. Maybe the soldering of one of the chips is degrading over time and bending the PCB reconnects the pads.
Nevertheless this cardboard fix worked.
I had to pay 59 euros to the FNAC store to let them say there was no spare pats to repair it! And this trick worked for me too! Thanks!
I found them to be quite easy to take apart with a bit of filling with a credit card similar to the newer xm4 disassembly guide. Sony WH-1000XM4 Battery Replacement - iFixit Repair Guide
I unscrewed the outer cover to inspect the main board and found no visual damage.
However upon adjusting the cable inside the ear cup and removing the protective tape in the central terminal I was magically able to get the left hand side working.
So if anyone else has this issue I recommend disassembly to have a fiddle around with the internal speaker cable.
Update:
Still no permanent fix 2 years later.
Today I tried all of the cabeling and even removing some of the insulation to try inspect where it could have issues.
In the end I just accidentally tapped the left speaker driver, Which is a big magnet (oops), and it seemed to resolve the issue. At least for now.
These headphones still sound great and really hold up well.
worked like a charm. saved my 16 hour flight just 30 min before going to the airport. was my last ditch effort.
it works for a moment, but the second i try to put it back together the cable moves again and it isn't working anymore. any suggestion which cables are the ones that need to be fiddled around? if i knew that i could probably secure them somehow
I've just placed a strap of duct tape over the wires in the left ear cup, which seems to fix the issue
Which cables do I need to move around I've tried to no avail please help
I found that it has something to do with the driver on the left ear. It seems to be extremely sensitive to contact or pressure. When I had my headphones apart, tapping on the driver got it working. I was able to put my headphones back together, and listen to music, but the slightest bump cut the driver out again. Back to the workbench.
Hey there , I have the same issue: my left speaker isnt working anymore. In the past I could get it to work lightly hitting the outside of the left ear cup, but that does not work anymore. Connecting the cable does not change anything. I already opened the left side ear and had a play with the cables, to no avail. also there was no obvious damage visible. Anybody got an idea what I can do? Help appreciated :)
Hey Mister P,
try to lock the cables on the board with duct tape, this worked for me.
If connecting the AUX cable does not fix the issue it sounds like the speaker may have a wiring issue. Might be worth inspecting the PCB.
Hey there, I took the speakers apart and resoldered most connections on the PCB and on the speaker - with no avail. I also had music playing through them and fiddled with the cables, but nothing changed. Running out of options here i fear :( If anyone has more input I would appreciate that !
I Tried tapping the speaker with a screwdriver last night and that seemed to work great. I think some units just have speaker driver issues.
could you expand a bit on where you hit the speaker? i am running out of options and dont know what else i can do
After taking of the ear piece and separating the pieces, I checked all the connections and tried electrical tape to cover the exposed wires without luck.
So I put a piece of slim leather between over between the outershell (with microphone sensor) and internal board and screwed it back together,
BINGO, it works for now. The problem seems to be some arcing across the outer and inner components, which the cardboard solution pointed toward.
Thanks guys. Nice to save these great and expensive headphones. Now I can work at home again, while my family dances and rocks out without disruption.
When I dissassembled my WH1000XM2 headphones I discovered that it was not a wiring problem but the speaker itself. I left the headphones switched on with music playing. When I applied pressure to a particular spot on the membrane of the speaker using a plastic tool, I noticed that it started to emit music, when I removed the pressure it stopped emitting music. If only I could keep something there in place of the tool, I thought.
So I grabbed some thin cardboard packaging (a teabag carton, if you must know), cut a strip of cardboard about 3 cm long and about 1 cm wide and folded this over on itself (rolled more like it) so that it was under some tension and then placed it up against the speaker exactly where I had applied the plastic tool. After some adjustments and re-cutting the cardboard strip so that it fit snugly into a gap in the plastic housing on which the speaker is mounted. Voilá. It worked. I'm sure its only a temporary solution, but I hope it will last until I manage to select and order replacement headphones.
I hope this may help someone.
I made this account just to say, I just fixed my girlfriends pair with this method. Thank you so much!!!
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 121
Altijd: 8,944
2 opmerkingen
Same problem. Used these for years, and suddenly the left ear stopped working. Cut some card stock and stuck it in the left earcup. Worked like a charm. Saved an expensive piece of kit!
door Jeff Gibson
I still have not been able to find a permanent fix 2 years later.
I took them apart and tried fiddling with the insulation. But I dont think this was the cause of the issue.
I tried tapping the speaker with my screwdriver, (huge magnet oops), But this has semingly fixed the driver issue and it is back working agian.
Although I cant narrow it down.
If you are having intermittent problems with one of the speakers I think it may just be the physical driver getting stuck?
door X West
