Why is my power tailgate constantly trying to open and close by itself
Why is my power tailgate constantly trying to open and close by itself sometimes?
Is dit een goede vraag?
Hi,
When it happens can you stop it if you engage the vehicle in gear when the vehicle is stationary?
Does it occur when driving?
If the answers to the above are Yes and No then it may be an intermittently faulty left or right side pinch sensor (part #13)
@ckmoybriarfield1
The pinch sensor is still available if you search for the part # only i.e. 4894033AE for left and 4894032AE for right.
I was intrigued by your question so looked up the service manual where it stated that the liftgate would not operate under the conditions I stated above so I mentioned the pinch sensors as one possible cause that it might when the car was not moving.
That is not to say that it is the cause of the problem. The liftgate can operate due to inputs for other things such as keyless entry or driver side liftgate key operation.
I thought of the sensors because if one detected, incorrectly that there was an “obstruction” when closing it would stop and open the liftgate and when the “obstruction” was removed it would close it again. An intermittently faulty sensor could cause this more than say a faulty switch although they could as well, but you have to start somewhere.
Maybe try placing an obstruction e.g. box, in the liftgate area and check that it does do what it’s supposed to do when closing i.e. encounter the obstruction and auto reopens and then tries to close again properly when the obstruction is removed
Alternatively, you could try disconnecting one sensor (they are in series connection so effectively both are disconnected - see 2nd image, p.8W-61-19) and see if the problem stops. Hopefully doing this won’t cause any other problems ;-)
As seen in the attached images it is getting a bit involved with all the electronics as everything is controlled by the liftgate control module, in conjunction with the power train control module and the body control module.
There is a scan tool available (presumably at dealers) that can test the operation of all the modules and check for any error codes that may be stored.
(hover the cursor over the image and click on the magnifying glass symbol to enlarge, when the new window opens with the image, click on the image again to enlarge it even further)
I don’t know what will happen if you disconnect the power to the liftgate, except possibly that it cannot be opened. You may get indications of a liftgate open condition, even though it is shut due to no power through the modules etc
Was dit antwoord nuttig?
It can occur anytime and even when the van Is turned off. But I see the pinch sensor has been discontinued, What else can I do to repair this problem? What will happen if I unplug power to the latch assembly?
Just pull the fuse j22
Sorry, for this is not an answer, I have the same problem & more. I could leave my 2011 Grand Caravan R/T, and come back to it, and find the back open, windows down, side doors open, or the vehicle running. I tried all the suggestions, and I didn’t want to disable these functions, for I have a lift seat installed, to lift my wife into the vehicle, in that she has MS. I now, after turning off my vehicle, place my key fob in aluminum wrap. I have also done this to my spare set, because the vehicle’s horn would start beeping all through the night. Since wrapping them, the horn no longer beeps at night.
If I had not had a lift seat installed, I would get rid of this vehicle, but the size & adaptability of this vehicle is great. I wish there was an easy solution, or even a hard solution. There is no conciliation in knowing so many others are going through the same problem, and Dodge/Chrysler has no remedy for the problem.
It's interesting to find another 2011 Grand Caravan owner dealing with this same issue. As I sit here taking turns typing and reclosing my tailgate via fob ggrrrrr.... I also have just started to wrap my fob in foil otherwise I return to windows down and doors open as well. Hopefully someone figures out a solution for this as I am constantly worried about leaving anything of value ever in van lest it gets openly offered to thieves passing by.
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 156
Altijd: 5,820
