Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
found a broken iPhone 12 max
I'd like to fix this thing and either return it to it's original owner or sell it. The screen is shattered and it does not at all respond when plugged in…..but there seems to be no water damage and the frame appears perfect. i have a $200 quote for a new screen installed. what should I do?
Is dit een goede vraag?
1 Opmerking
You could try to see if siri will work and ask her "who do you belong to" and she will tell you about who the iPhone belongs to. That's all she will tell you. You could also try to ask her to call "mom" or "dad", but I'm not sure if the phone will let you use siri after a restart. Now if you don't want to return this phone to the owner and you want to keep it, I recommend reading the answer by Chris Stables. Good Luck!!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You will have to presume the phone will be iCloud locked. I would connect it to your pc or mac and see if it is recognised, you will probably need to put it into DFU or recovery mode if it has a passcode.
The only way to find the owner would be if it has not got a passcode and you can view there information but this will be highly unlikely.
 You really need to find the lock status before spending any money. You could try restoring it via 3uTools or iTunes and see if it will activate, you shouldn’t need a working screen for this. Or see if there is an IMEI number on the sim tray which you could check on a website.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kurt Schasker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 491
