Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20009 Vragen Bekijk alle
How to repair the Magsafe i/o Board?
Does anyone have any ideas for repairing a damaged Magsafe i/o board for a Macbook Pro? I specifically have a early 2008 15" Model. I realize that I can replace the i/o board, but I would rather learn how to repair it if possible. Has anyone fixed one? Any thoughts on what might be damaged? I have no problem with desoldering and replacing components if it's cost-effective. These boards are all over ebay refurbished, so someone must know how to fix them. Your advice would be appreciated! Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This part can be had at some places for $6.50. I order them about four at a time. Yes, I have repaired them by cleaning but I've never seen one that needed to be re-soldered. I also don't cut my lawn with scissors although it could be done. A better use of your time might be on repairing high end video cards. Spending thirty minutes or an hour on a $150 to $350 card would seem like the way to go.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
$6.50? Would you be kind enough to share a link to a site that has them for that price? That would be fantastic!
door
Voeg je antwoord toe
Josh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,545
