Ga door naar hoofdinhoud
De Flip Mino HD, uitgebracht in 2010, is een zakformaat camcorder met 4 GB aan opslagcapaciteit en een uur opnametijd.
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
Was dit antwoord nuttig?
Score 1
9 opmerkingen:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
door
@TechVid How many wires is in the ribbon?
door
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
door
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
door
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
door
4 commentaren meer tonen
Voeg je antwoord toe
TechVid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 484
