Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De HTC Inspire 4G is de eerste smartphone die door AT&T Wireless als "4G" op de markt werd gebracht. Het is niets meer dan een Desire HD die vergrendeld is voor AT&T en op AT&T-software draait.
Is this VoLTE compatible?
I was tasked with erasing and disposing of this phone (and an SIII), and I do not know if it supports VoLTE 100% - my initial checks (T-Mo IMEI checker- hard no, as it uses weird bands being an early 4G phone, Mint Mobile says no and sim-usa.mobi) point to a hard no, but I’m not 100% sure because I do not know for sure as these are very approximate.
I’m not going to take this phone to AT&T as I likely know it’s a hard no, but I’m just wanting to see if it’s going to hold up after the 3G shutdown in 2022. The SIII I was tasked with checking is not which I know, but I have to get the owner’s photos off and get them to her before I erase it too. Does anyone know if this phone will work with VoLTE or is it at the end of the line?
If it isn’t I’ll be a little burned here, as I did the S-OFF mod and SIM unlocked it with an exploit when I was younger so even then, I might just be tempted to “forget” to check it. The owner doesn’t know.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
The HTC Inspire 4G does not support VoLTE, since it doesn't support LTE. In addition, you will not be able to sign in to a Google account on this device.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yeah I might junk it and get a used Moto One 5G ace to toy around with and bootloader unlock if it's that bad. Yeah, yikes. It's like the 2.5G phones with the HSPA+ backhaul.
door
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 337
