Ga door naar hoofdinhoud
Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
Is dit een goede vraag?
3 opmerkingen
I am curious if you found a good solution for this?
door
@grayraver See oldturkey03's answer
door
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Do i need to connect with a parallel connection?
door
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
Voeg je antwoord toe
Randy Northrup zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 581
