Ga door naar hoofdinhoud
De eerste generatie van de compacte sportcoupé, de Scion tC.
Why is my RPM too high at lower speeds and car not shifting into third
Got a used engine under 55k mikes installed at auto shop due to a failed piston compression in my previous one. Get the car back a week later told it’s fine to drive. Come to find out that the RPM’s are way too high going a slower speeds. Took it in again and had them check the transmission and they installed a new filter and topped off fluid. Still having same issue but they told me that the car needs to relearn when to shift since but i drove it over 20 miles at various speeds and is doing the same thing. I told them to check the ECU but insisted that it just needed to relearn. What is the issue?
Is dit een goede vraag?
1 Opmerking
Save yourself time and headache and take it to a Toyota dealer\shop.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
If it IS the ECU needing to relearn… check this website: https://autoguysland.com/how-long-does-i...
It has helpful information. 20 miles may not be enough for it to fully relearn everything. It can take a bit longer than one would think. If you still think something is definitely wrong then I'd advise taking to a dealership. It could be that your TCM needs flashed.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Christian Agullana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 495
