Ga door naar hoofdinhoud
Samsung un55ks8000 turns on but black/gray image power light blinks 7
My Samsung un55ks8000fxzc started having this problem where when I turn on the tv all I see is a grayed out image and the red power lights stays blinking 7 times. Then it power cycles and keeps repeating the same steps.
Any idea what it could be?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
So I was able to get the TV to turn on and return to working order by taping 3 of the lines on the ribbon cable inside the TV. I followed instructions on a video online. Right now everything is working but I just want to know if this fix will stay and if there is something more permanent like replacing a part which I can do . Any info would be appreciated
Was dit antwoord nuttig?
2 opmerkingen:
@godfather17 which video did you check so that we can see what lines you taped....?
door
There are several videos online. One in English and one in Spanish
door
Voeg je antwoord toe
Godfather17 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 86
