Ga door naar hoofdinhoud
4K Ultra HD, 3D, Hi-Res Audio Wi-Fi Built-In Blu-ray Player
UBP X800 with no Home Menu
It seems that the UBP X800 only show home menu after playing blurry disc.
The blu ray is connected to a pre amp connected to a sony Oled.
In the sony Oled the bluray appear
Thanks.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @ronenza ,
“…no home menu…” or “…only show home menu…” which is it?
If it doesn’t display a dvd video but only displays the menus try cleaning the laser lens and check if that resolves the problem.
If still no good try performing a hard reset on the player and check if that resolves the problem.
Scroll down to the last post in this link and click on Expand Post to see how to do this.
If it works check for any firmware updates for the player. Search online for Sony UBP X800 firmware as there appears to be one released just recently. I don’t know if this one is applicable for your region so that’s why you should check for it from where you are. Alternatively, if the player is connected to the internet and the Home screen menus work then use the Update Firmware option in the Setup menu.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ronen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 582
