How to fix broken ram slot
One of the two ram slots broke, is there a way to fix it
Is dit een goede vraag?
There is. but your not going to like it. but contact Louis Rossmann of Louis Rossmann group in NY New York. he may be able to repair it. https://www.rossmanngroup.com/
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 200
6 opmerkingen
@danj do you have any idea?
door Ben Capehart
What broke? Post some pics so we can see Voeg afbeeldingen toe aan een bestaande vraag
Most of the time there is little you can do as the frame is well anchored. You would need to replace the frame which is not easy and the cost would be more than replacing the logic board. If the latches are damaged you can try wedging some plastic to hold the needed pressure on the SO-DIMM.
door Dan
@danj its not the frame or latches,
Its the slot, a picture wouldn't be very useful,
The problem is inside the slot
door Ben Capehart
@beanman56 - New frame then, I would just replace the logic board at this point MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
door Dan
:| don't want it THAT much,
But thanks again @danj
door Ben Capehart
1 commentaar meer tonen
