After screen replacement battery not showing or charging
So after replacing my screen, my macbook does not work without the charge cable, en booting or even opening Safari takes like 10 minutes.
Loud fan noises everything is laggy i can't even do a cmd + R cause booting causes like 10 minutes.
Before the screen everything was charging fine and working perfect, but now i can even work with it.
Anyone knows what the isseu is here?
Paid info:
Battery:
Is dit een goede vraag?
5 opmerkingen
Did you check the connections did you not get the connections properly set?
How about running the onboard diagnostics to see what it tells you. Restart your system and press the D key
Reference: Mac startup key combinations
Lastly, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
The connections are good, I am now trying the D key so its recovering. I keep you posted!
Thanks a lot for the quick answer!
door Danny Dog
@danj Update: after pressing D and waiting like 10 minutes is chosen my WIFI and after password it kept loading for 4 hours en now i forced it to stop. So no succes even with the online recovery its horrible slow and laggy and loud fan noises.
door Danny Dog
@dannydog - Sorry to hear that, Not sure why your system would do that. Are you able to get CoconutBattery working? If you can get that running a post a snapshot of it that might offer a clue.
You could try installing this great App TG Pro it will show you the sensors (including the batteries) If you get the full version it offers a bit more info.
door Dan
@danj Just updated my question, after 4 hours struggling to install tg pro these are the results.
door Danny Dog
