Ga door naar hoofdinhoud
Repair guides and support for televisions manufactured by Panasonic.
3 blinking red led fault code
Panasonic TX-P42X60B
I am trying to get the panel for this TV as I think it is the power panel that is fault
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@electric151 the 3 blink code for your TV model is most commonly caused by a bad A-board. That is your main board. Of course, the 3 blink code is not listed anywhere. So, it’s a bit of a gamble. I’d check the power board output to the A-board on the connector. Check to ensure all voltages are present as listed on the print on the board. IF they are, then you pretty much should try to replace the A-board.
Was dit antwoord nuttig?
Voeg je antwoord toe
Alistair Dunn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 134
