Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de 5e-generatie Apple iPad met 4G LTE, verkrijgbaar met 32 of 128 GB opslagruimte. Uitgebracht in maart 2017. Te herkennen aan modelnummer A1823. Voorzien van een 9,7" Retina-display en 64-bit A9-processor.
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
Was dit antwoord nuttig?
1 Opmerking:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
door Deel
Voeg je antwoord toe
Chris Reader zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 370
