Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy A71 is een Android-smartphone die door Samsung Electronics wordt geproduceerd als onderdeel van de Galaxy A-serie. Hij werd uitgebracht in januari 2020. Versies: SM-A715F/DS, SM-A715F/DSN (Globaal), SM-A715F/DSM (Rusland).
Screen Issue Yellowish Pale Bright
My Samsung Galaxy A71 (Not 5G one) have a screen issue, The screen flickering and then become Yellowish and Brigther, Everything that usually black it become brown (such as Youtube Blank Space that doesn't fit / AOD / Samsung Logo when restart) First it's change from normal to yellow and then it's become permanent yellow full screen, flickering to normal sometimes or brighter and darker version. Everything looks pale and bright some sort of contrast maybe? I've try safe mode but it's still the same. I'm asking first because I don’t want to factory reset.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
It sounds like you have either a bad display or an improperly connected display flex. Have you had the phone repaired recently?
Was dit antwoord nuttig?
2 opmerkingen:
No I haven't repair my phone before.
door Deel
In that case, you could take it to a repair shop so they can take a better look at it, or you could try replacing the display. However, with Samsung's phones, you have to go through the back to replace the front, and sometimes the back cover can break if you aren't careful.
door Deel
Is there a fix for this issue? I have this issue rn. Usually screen turns black whenever i go through something black or when screen is hot
Voeg je antwoord toe
Gunsøu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 1,302
