Vauxhall vectra 06 blowers not turning on
My vectra blowers will not work on any setting. I’ve taken the glove box apart and tested the current and the fan is getting power and also works when testing from another loom. I have replaced the resistor but still nothing. Also checked all the fuses. Would this mean there’s a problem with the switch? As in where you turn the blower on from? The button for the dentist also doesn’t turn the blowers on. At a loss and don’t want to keep replacing bits to find out it’s not that! Any help much appreciated
Is dit een goede vraag?
devlish_angel2k3 you lost me with this "The button for the dentist also doesn’t turn". Have you applied power to the blower motor directly to rule it out as being defective? Since you have power to the blower motor and resistor pack have you checked the relay? Should be somewhere above where the glovebox is.
door oldturkey03
Sorry predictive text! Was meant to say de mister. Yes have checked off of another loom for the motor and that runs fine as well. It just doesn’t when it’s all connected together. There wasn’t even any issues such as only working on number 4 it just doesn’t work at all. The buttons on the panel for air con etc all light up when pressed.
door devlish_angel2k3
