Ga door naar hoofdinhoud
Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in 3D on the top screen.
Flashing Power LED - Not what you think...
My New Nintendo 2DS XL power LED flashes red as if the battery is about to run out, and shows the battery icon on the home screen with a single bar of power left.
The battery is not actually about to go flat though. Regardless of how much charge the battery has, the 2DS XL thinks it is about to go flat. I can play for hours with it flashing and it will be fine but I will have no idea when it might actually run out of battery, so realistically it can only be played while charging.
I can very temporarily fix the issue by letting the buttery run completely dry and then charge the battery. When I turn it on it will have a blue light and proper charge, but at some point goes back to flashing.
Would replacing the battery fix this, or is it more likely a connector or something else?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Just realized I never came back with closure.
I opened up the case and painfully removed the battery (2DS XL batteries are "not replaceable") and put it back in. That's all it took for the battery to work properly. I've been using it a bunch these past 2 years and it has behaved correctly ever since.
Was dit antwoord nuttig?
Het nuttigste antwoord
@fliggle_slaps start with a new battery. It sounds like there are issues with the “Gas Gauge”. Even if the battery does not resolve it at least you have a known-well starting point should further troubleshooting be needed. New Nintendo 2DS XL Battery Replacement
Score 1
Voeg je antwoord toe
Fliggle_Slaps zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 1,597
