No water, no ice and no freezer light, suggestions?
Model GFE26GMHFES, French Door, Bottom Freezer
I have no water, no ice and no freezer light. I no longer have the option/display on the front control to turn on/off the ice maker. It all happened at the same time. I have good water pressure. The water does not flow past the water valve in the back bottom of refrigerator. I replaced the water valve. Still does not receive the signal to send the water. I have tried everything here to include Sabbath mode and all the other “pressing/holding” buttons.
I have replaced the board for controls, water/ice valve inside left door, freezer light, and freezer door switch. I am bypassing the water filter with the bypass plug (tried a new filter also). Everything else is working fine.
When this happened, my fridge wasn’t cooling as well as it should. I had a repair guy come and look at my fridge and he replaced the fan in the refrigerator section. He spent the next hour trying to figure out the rest. He was frustrated and couldn’t fix it. Any ideas?
Is dit een goede vraag?
2 opmerkingen
I have the same problem. No water or ice will dispense and the freezer light went out all at the same time. All this started working again about six weeks later for about a week before going out again and has been out since. Repair man could not find the the problem.
door Ojohnson
@ojohnson98257
What is the model number of your refrigerator?
door jayeff
