Ga door naar hoofdinhoud
The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
3 Vragen Bekijk alle
New battery only works while plugged in
I just replaced my battery in my razer blade stealth and it works fine while plugged in but says charging and stuck at 97% and when I unplug it it turns off immediately and won't turn on while unplugged. The battery is brand new. The old one was fairly bloated.
Is dit een goede vraag?
Score 3
3 opmerkingen
does the laptop power on without a battery?
door
@logixal yea it will power on without the battery connected
door
Exact same problem!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@riveteer I am certain you double-checked your work and made sure that your connectors are all properly seated and that there are no issues like bend pins etc. with those. I would contact the seller and replace the battery once more just to rule it out as the culprit.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yea thanks. I did look around more today and was looking at the connector for the original battery and the one I bought from ifixit had a poor connector. I bought another and plan on returning the one I got. Thanks
door
Voeg je antwoord toe
Jack Kuckhahn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 788
