Ga door naar hoofdinhoud
Reparatiehandleiding voor alle toetsenborden behalve die van Apple.
242 Vragen Bekijk alle
Logitech type+ keyboard won't turn on
My sister has a Logitech Type+ keyboard for an Ipad. It does not have replaceable batteries, they are rechargeable. The green light comes on when it is fully charged. When the Ipad is placed on the magnet hinge the kbd does not turn on. It should turn the light green, then flashing blue, then solid blue when paired. Nothing lights up. I am assuming there is a problem with the switch mechanism in the magnet but I can’t find any disassembly pictures to see how it works. Any ideas?
Is dit een goede vraag?
1 Opmerking
I read the instructions closer. When the battery goes that's the end of life for the device.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @pwansley
Not sure if this is the same keyboard but here's a video that shows where the two CR2032 coin cell batteries that power the keyboard are located.
Worth checking anyway.
Was dit antwoord nuttig?
Score 1
It doesn't sound like the battery, if you are still getting valid charge indication. The enabling action is via the magnet, so I think you're on the right track there. The keyboard will wake when keys are pressed, but I assume you've tried that. Alas, I have no experience with these things.
If it is the battery, I don't think it's ends-of-life. Logitech shows an internal prismatic battery with a cable and connector (not CR2032 as suggested above -- those are for another keyboard). However, they only mention removal for disposal, and do not call out the battery type.
Careful use of a spudger should enable you to open the keyboard, and the battery will likely be labeled with a part number, chemistry, and capacity. You can probably find an exact replacement.
Voeg je antwoord toe
bill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 33
Altijd: 472
