Ga door naar hoofdinhoud
Dell XPS 2-in-1 laptop computer. Released early 2018, model number 9575.
6 Vragen Bekijk alle
New replaced battery is not charging second time
I replaced the battery on my laptop, following the instructions to charge it for 100% and extra 2 hours, then I used my device till it shut up and started to charge it again. But now my battery is not charging higher than 66%. What can I do? Thank you in advance for the answer.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I’ve replaced my 9575 battery twice and never had the problem. It’s possible that the battery is defective, but first check what the bios reports for the battery status. Also, check your battery charge threshold in either the Dell Power Manager or the bios. Dell allows you to configure custom charging thresholds on your battery (battery only charges below a certain limit, and doesn’t charge above a certain limit), maybe somehow that got activated in some way?
Was dit antwoord nuttig?
Voeg je antwoord toe
Natalia Petrova zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 177
