Ga door naar hoofdinhoud
A1706 / EMC 3071—Deze 13" MacBook Pro werd uitgebracht in november 2016 en introduceerde de OLED Touch Bar. Beschikt over een dual-core "Skylake" Intel Core i5 processor en vier Thunderbolt 3-poorten.
Touchbar dead after keyboard replacement
Hi, I have replaced the keyboard and backlight on 2 MacBook Pro A1706s. This is just the keyboard and backlight, not the entire topcase.
The issue I have is that the Touch bar is dead on both of them. If I disconnect all the screws and flex cables except for the touchbar, power button, keyboard, touchpad and TB and boot the Mac the Touchbar works on both.
If I connect everything i.e. screws and all flex cables the Touchbar is dead. Exactly the same on both. I have done the usual NVRAM, SMC, macOS install and it does not fix the issue.
I have taken everything apart and checked the logic board and the flex cables under a microscope and I find no issue. Everything looks fine.
Because I have the same issue on both devices I’m wondering if it is the keyboards as I got them from the same supplier. Has anyone got any experience with this issue or have any ideas ?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
On my MacBook Pro A1706, the touch bar worked before the keyboard replacement and stopped working after. After some debug, I found that under the corner of the motherboard that has the touch bar connector (near the hinge closest to the keyboard's "1" button) there is a short "elbow" ribbon cable with a small component (with a metal top) on the end that is meant to be flush with the back of the keyboard. This component was not sitting as low as it did before the keyboard replacement, so when the motherboard was screwed down, the metal top of the component made contact with something on the motherboard, stopping the touch bar from lighting up due to a short circuit. I fixed it by putting a small piece of tape (I used Kapton tape) over the component as well as on the motherboard in that area (you can see several gold test points there on the motherboard along with a couple of very small components). After screwing down the motherboard and reassembling, the touch bar worked like before.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thank you sir
Your Valuable Information
door
You saved my day! Thank you!
door
You saved my life!
After my keyboard replacement (keyboard only; without topcase) the Touchbar stopped working. I inspected the flex cables and the connectors but everything seemed to be fine. After your hint by isolating that area my Touchbar works likes new again!
I was about to order a spare one but you saved me 😊❤️
Thanks a lot
Greetings
Tolga
door
I think you nailed it you have a bad keyboard unit!
I would look at the TouchBar power rails, I’m suspecting one is being shorted out when you tighten the keyboard screws. The other possibility is you are a long screw when a short screw should be.
Look at the old keyboard mounting points to see if the new one matches exactly the same exposed areas where the mounting screws are located.
Given the difficulty I prefer to replace the full uppercase assembly.
Score 1
1 Opmerking:
I agree with replacing the full uppercase assembly, I am doing a 2016 15" right now. I will be putting in new speakers as they are so hard to get out without damage. To bad there were no guides on doing this.
door
Voeg je antwoord toe
Bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 1,220
