Ga door naar hoofdinhoud
Magnetische 2e generatie AC-lichtnetadapter voor MacBook-producten, voor het eerst uitgebracht in 2012. Niet compatibel met systemen van de vorige generatie. Verkrijgbaar in 45W-, 60W- en 85W-uitvoeringen.
Problem with MagSafe2 Power Adapter after replacing the cable
Hello
I replaced the cable - MagSafe 2 (the old one was cut). After that i have a problem with charging. I have to plug the cable into the socket on the computer several times until it starts working. When I do that I can disconnect and reconnect and its ok but.. when I unplug the cord from the wall socket it not working again (charger reset?) ..
I have already try with 3 new cables (original) and problem is the same. When I use my old one its fine..
Do you have any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sadly it’s time to just get a new charger. I’ve never been a fan in patching the cable together as the connector has a tiny chip inside which tells the system what the charger is.
Why this is important is the voltage and needed charge rate is not the same across all of the chargers. So the cord you snagged may be for a different charger! Here’s more on this Teardown and exploration of Apple's Magsafe connector
So what to get?? Don’t waste your money on the knockoff chargers they are just not safe! Lacking safety features, cheap MacBook chargers create big sparks which can harm your system as well as set fire as my ex-employer found out having to fork over 4 million for one of their employee setting a hotel ablaze!
So get a REAL Apple unit directly from Apple as the sellers who claim its a real unit (or state OEM) are not selling you a real Apple unit. Fake Apple MacBook MagSafe2 charger, how to tell a fake, eBay scam
Here’s the chargers directly from Apple’s web site
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for respone. I will do that what you say :)
door
Voeg je antwoord toe
Konrad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 781
