Ga door naar hoofdinhoud
Chrysler debuted the 2008 model year Town & Country went on sale on August 16, 2007 as a 2008 model.
25 Vragen Bekijk alle
Fan and stereo turn off randomly while driving.
(2010 Chrysler town and country touring)
As the title states, the power to my fan and stereo systems turn off randomly while I am driving. They always turn off and on together, which I think indicates that the problem is not in either of their individual wiring. They turn on for a couple minutes at a time, then turn off minutes later. It seems like vibration may play a role, since it turns off and on more frequently at a slower speed.
The cabin lights, odometer LCD, and ignition all work.
possible guesses:
Defective relay?
Issue with the onboard computer?
Wiring issue?
Thank you very much for your help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It sounds from the symptoms like a grounding issue. You'll need to get in the dash and follow the grounds. Likely they connect together and go to a grounding screw/bolt on most likely the passenger side pillar. They get power from separate places, so I'm thinking the grounding side is where to start chasing it down.
Was dit antwoord nuttig?
Voeg je antwoord toe
Isaiah Moorehead zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 43
