My samsung s7 needs motherboard. Change. It was purchased in usa. Is i
Local repair person says to replace motherboard of s7. Samsung mobile. Can we get motherboard. Os samsung s7
Is dit een goede vraag?
You should be able to get a replacement board just make sure the model number matches what it already has. So for example if it’s an SM-930U make sure the replacement board is an SM-930U. If you don’t use the same model board it won’t work properly. The cameras may not work or you’ll get a “No Sim” message after you put one in because there are a few different versions of charge ports and rear cameras.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 82
1 Opmerking
Thanks for reply. I will follow your advice.
door Srinivasan Krishnamoorthy
