Ga door naar hoofdinhoud
Laadstation voor de DualSense PS5-controller.
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
Is dit een goede vraag?
Score 3
1 Opmerking
did you ever find a way?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
Was dit antwoord nuttig?
Score 2
See my teardown over at Dualsense Charging Station Tear Down Guide
Score 2
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
Voeg je antwoord toe
Sulakshan Rajaratnam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 54
Altijd: 2,158
