Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Vragen Bekijk alle
Different battery connector on 15" mid-2012 nonretina MBP?
I bought a working 2.6Ghz motherboard to drop into my mid-2012 non retina MBP from ebay, everything looked fine then and everything else reconnects internally, but the battery connector for some reason is a straight inward connector and not the vertical drop in one. I can’t find a single image of a battery using this connector online, just the typical L shaped plugs. Has anyone ever seen one of these?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
They shipped you an older 15” MacBook Pro Unibody (Mid 2009-Mid 2010) logic board! MacBook Pro 15" Unibody mid 2010 Vervanging van de batterij
You got a Intel Core 2 Duo board instead if the newer i-Series i5 or i7 CPU’ed board your system came with.
I would return it and get your money back ASAP!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
That... wow. Definitely packing it back up to start the return process, not even sure how someone could mislabel a board that badly.
door
Voeg je antwoord toe
enig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 30
