Why is the picture so dark?
Every time I turn on my Xbox 360, the image is very dark and a little blurry, even after a hard reset but seems to work fine otherwise
Is dit een goede vraag?
Did you open the Xbox and look for leaking or bulged capacitors? Here is an image for reference.
Was dit antwoord nuttig?
Yes and I did notice one next to the CPU, it was one of the bigger 4, could this be causing it by any chance?
Yes, bad capacitors could cause a dark picture. Could you give me the brand and series(e.g. Nichicon HM), in addition to the uf rating and voltage?
Rubycon 6.3V 2700uf
I think it says MFZ under the numbers as well
You can replace it with https://www.digikey.com/en/products/deta... from Digi-Key or https://www.mouser.com/ProductDetail/Rub... from Mouser
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 277
3 opmerkingen
@cwr81 you have tried a different TV just to make sure that it is not the cause.
door oldturkey03
Yes I have tried a different tv, same effect, very dark, also I have tried another Xbox 360 I have to make sure it isn’t any of the cables but the cables are fine.
door Nascar1243
I did also try a reflow of the CPU and GPU and the RAM and it still has this issue, I did notice a bad capacitor next to the cpu, could this be the issue?
door Nascar1243
