Ga door naar hoofdinhoud
2.3L 4cyl or 3.0L V6, 6th Generation
2001 honda accord - green key light on dash does not always come on
2001 honda accord - green key light on dash does not always come on. When it comes on the car will start. If it doesn’t come on it will not start. Never can tell when it will come on- its intermitent. Car has died only 2 times while driving. I have 4 programed keys and it happens with all the keys (its’ not the chip in the key)
i think it is either the immobilizer, steering switch, or is it some random ground problem.
Anyone have any idea
Is dit een goede vraag?
1 Opmerking
When the car died while driving... was that from the immobilizer?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
found a print circuit board on your immobilizer relay underneath the dash by the steering column black relay single plug had to we solder print board where the two relays contact to the board to resolve problem
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I resoldered the RC-5402 relay inside the immobilizer unit to fix the "no green key" issue on my '01 Accord LX 2.3L.
door
To clarify, the relay contact points were resoldered to the printed circuit board.
door
the chip in the key is a transponder and there is also one in or around the barrel or behind the dash and the frequencies marry up to each other in order to start the car and does hand in hand work with the immobiliser so the transponder in the car may be a possibility don’t rule it out fully. could be faulty wiring or water getting into the system. if that green key light is on and off intermittently my guess would be loose wire or water shorting something in the system every so often which is immobilizing the car and that’s why its shut off whilst driving but not all the time
Score 1
It's theft perfection look on you tube and reset theft perfection forget how but lots like turn key in driver door like 3 time one way and the other then other way and it will reset theft pertection
Score 1
3 opmerkingen:
Green light will come on when I beat on the steering wheel
door
Yes my honda dose that some of the time a hello did you fix it
door
If you’ve tested the voltage/ conductivity to immobilizer & you have the right key programmed to the immobilizer(dealer) & the green key immobilizer light doesn’t always come on, it could be that the brake switch/ lose wiring/ bad connector/ which will not trigger the shift solenoid under the console. I replace the solenoid/some wiring & brake switch but still had to tap the brake like 20 times.. I finally noticed that when I depressed the brake fully & released it so it hit the brake switch harder, it would cause the green key to show on the dash & would start. I later wiggled the brake switch/ connector & it made the green key show up so don’t rule this out either. There is also a brake code that the dealer has for your vin. It’s a 5 digit code, that you can use to start the car/ get home etc, if your immobilizer suddenly fails. Big picture is,both the immobilizer & shift solenoid have to send a signal back to the ECU b4 you’ll see the green key illuminate on the dash… 2001 Honda accord 2.3l DX
door
Voeg je antwoord toe
mary zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 75
Altijd: 5,821
