Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
5 opmerkingen:
any issues before the clutch change or just a routine change?
If it does not crank at all I would look at clutch safety switch. If it does not crank. Check to see if you have spark. And check to see if you have fuel pressure. Some times the wire running to fuel pump is near tranny. And can get pinched or cut while removing
door jay
No issues aside from burnt clutch
door John Barrett
does it crank over at all the engine or is there no signs of life?
door jay
I know a clutch job can be quite involved depending on the vehicle but did you check to make sure everything was connected?
door Jesse Hooton
door GKJarhead
