Ga door naar hoofdinhoud
This page includes repair guides and technical reviews of Huawei Mate 10 (released November 2017).
14 Vragen Bekijk alle
Battery compatible with Mate 10 Lite?
Does anyone know if the battery ifixit sells for the mate 10 is also compatible with the mate 10 lite?
https://store.ifixit.de/products/huawei-...
There’s no battery explicitly for the lite version. It’s so %#*@ hard to find the actual battery specifications of the phone, I just found the capacity which is higher in the above battery.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @kryptojude ,
They are different batteries.
The model number shown for the Ifixit battery that you linked is HB436486ECW (printed on battery)
The model number of the battery in a Huawei Mate 10 Lite as seen in this video is HB356687ECW - see image taken from video.
They have different dimensions and capacities and I don’t know if they have the same pin out connections in the battery cable.
Mate 10 battery dimensions = 4.3mm x 64mm x 86mm, rated capacity 3900mA
Mate 10 Lite battery dimensions = 3.5mm x 66mm x 87mm, rated capacity 3240mA (actual capacity 3340mA)
Here are the full specifications for the phone
(click on image to enlarge for better viewing)
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks a lot!
door
Voeg je antwoord toe
Kryptojude zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 402
