Ga door naar hoofdinhoud
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
134 Vragen Bekijk alle
Missing Hall sensor mystery.
My MacBook Pro (A1989) should have two hall sensors on most extreme position of motherboard. I found out, that my MacBook has only one. The other sensor pins has just connected two connection positions (middle two facing towards display). From time to time, it happens, that when I close the lid, Mac falls to hibernation, but does not wake up, when I close the lid. I am puzzled.
I was wondering, where to get second sensor, or how to make this more stable. I guess current state with shorted pins is but unusual.
Can you help?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you sure you selected the correct model here? This systems board number is 820-00850 Double Check. Take a picture of your boards hall sensor/s and where the missing one would be Voeg afbeeldingen toe aan een bestaande vraag
Update (06/21/2021)
@Ivo Hanuška - Your board number doesn’t make sense!
As you can see for these systems all are 820-xxxxx (five digits) Apple loves hiding it and the very newest one have a new code system a QR tag and a four alphanumeric code.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hi,
My board has different number, but very similar (if not same) layout. My number is 1320-2746. Pins are shorted by some form of glue/varnish. I was measuring resistance of connection and it was about 2 ohms. I guess this is some form of quick fix of previous owner. Maybe they blocked this sensor somewhere in software, since I had to clear NVRAM and SMC few times. I have no Idea what components are on sensor sub board I can not guess what should be output with closed and opened lid.
I just do not know and I’m puzzled.
door
@Ivo Hanuška - Please post some images so we can see things.
door
Voeg je antwoord toe
Ivo Hanuška zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 271
